Firmware Updater Not Working
I have a Transcend 2GB MicroSD card that the player no longer sees so I decided to check and see if a firmware update would fix it. I downloaded and installed the updater and, with 123MB free on the player was told that there was “not enough space” for the update. Any ideas?
Note: The MicroSD started working though.
Message Edited by Beliinus on 10-15-2007 07:17 AM
sometimes you may have to format the device THROUGH THE DEVICE, By settings, then format… and card for it to recoginze after a fw update…
