Firmware Update Question???
How do you know when their is a update to the firmware and how do you do it?  I always assumed the Sansa Clip updated automaticallt when you plug it in to recharge.
Thanks
There are 2 ways really you can download the Firmware updater and open it on occasion to check, or you can come on here and hang out with us and youll find out.
IIRC, when you install the Sansa Updater, it sits on your system always on, and so will update your player automatically once there is new firmware.  But for many of us, we don’t like the Updater sitting there eating memory (even of it is only a small amount), looking for an update that only will come every 3 or so months.  Easy enough to check here every now-and-again.
