Tried the update, not a good plan.
Now the screen only says “building database” for about 30 sec and then shuts off.
Tried the recovery procedure and tool with no change.
Tried the hard reset, “+ and Select”
Anything else I should try?
Taking it back is always an option.
Did you try the recovery tool? I didn’t get it to work but maybe it will help you.
When I did the update, mine had some weird problems also. After I reset it numerous times and pulled out my memory card it cmae back. But it still does not recognize my memory card.
Good luck.
