Firmware update 1.02.26A problem
New firmware does not read how many photos/podcasts in internal memory. Photos in external memory is read OK. I have done a reset on device numerous times, no change. SanDisk, please issue firmware update to return this function on device.
Try formatting the device by going to settings then system settings, then format. Then, reload your photos, and anything else that was on your Fuze.
I am going to try updating the firmware again with the Updater. If that does’nt work then I will use the Format option on the device and re-install everything again. Thanks!
