Hi all, recently I update my sansa fuze to 01.02.31F and now I have problem with my headphones.
When I set volume on 90%, my headphones “cut short”… as to the cable was break… but isnt it.
I want downgrade sansa fuze, but I cant find old version firmware.
Reinstall the firmware you have. When it asks for region choose REST OF THE WORLD. You are running into a volume restriction legislated by the European Union.
Or try the older version, but again, if you choose Europe you may have the same problem.
Are you sure the headphone plug is inserted completely into the jack? Try pushing and/or twisting the plug into the jack and see if that makes any difference in the sound.
I think that is the impedance… when I take impedance on the headphone, with I have a problem, I saw the impedance lower than is in datashet. It must be 24 ohm but I see 16 ohm on my ohmmeter. Maybe it is a problem.
In others headophones (with my sansa works good) are okay with impedance.
You cannot measure impedance with a typical Ohm meter, only resistance. Resistance is typically less then impedance for headphones.
