Hello! I’ve read that RockBox use battery much economical than sandisk firmware, is it actual for now? Or maybe it was already fixed? Are there many pluses to use RockBox (I don’t really like inteface)… I think to return to sandisk firmware, so, any advices? Thanks!
Here Rockbox not run on my Clip Zip.
http://www.anythingbutipod.com/forum/showthread.php?t=68698
You can take Skins for Rockbox.
Yes, I tried skins, but honestly I’m not impressed any of them… So, my question - are there real difference between SanDisk firmware and RockBox in battery usage, sound quality etc. Not interesting in skins, games, and apps
The Sound is not better general.
The EQ is better. With Rockbox can chance the 5 EQ frequency. And Parmetric EQ Settings.
Battery life is a lot better.
Thank you for answer. I will install RockBox … again
Do be sure to check out the various alternate themes (skins). In my opinion, many are very nice, as nice as the original firmware. Kudos to their creators.
OK, I just received my zip today, and on the rockbox website, zip is not supported.
on their website…
SanDisk : Sansa c200, e200 and e200R series, Fuze, Clip and Clip+
so how are you guys running rockbox on the zip?
You can find it here http://build.rockbox.org/ , or download automatic installer here http://www.rockbox.org/download/
PS: as for me, I re-install RockBox week ago, and did some settings and now I’m fully satisfied with it Choosed Clip+ theme (I don’t remember exactly how it called) and set Russian language ))
thanks I just downloaded the automatica installer, it say Clip Zip is Unstable…
Yes, because it’s still under development… but you shouldn’t be afraid – it’s pretty much stable
who cares, updated to 01.01.20 instead
I didn’t waste my time with 01.01.20…I’ve had Rockbox running for months.
it was asking for .bin file when I tried to install , do you know where can I get such a file?
It’s asking for the original firmware file which you can find here. Extract the .zip file and place the .bin file on your desktop (or other place you’ll remember where it is). Then tell Rockbox where is is (when it asks) so it can patch it with the bootloader during the installation.
In the event it won’t take the latest firmware version (which the RB developers may not have gotten to yet), use the previous 01.01.18 version here.
just installed rockbox, but it can not display Japanese, comes in boxes.
Switch to a font like unifont that has Japanese characters. You can download fronts from the rockbox web page under the “extras” link.
