File Recovery
Hi, I just started using SanDisk Secure Access 2.0. And I did not know that it auto save in temp file when I press “ctrl + s” in my word file instead of my designated folder . Is there a way to recover the saved file, after I removed the pendrive from my pc? My whole day worth of work is in that file. :cry:
unfortunatelly the secure access vault logs out automatically after some time and if you are working on a file that is stored inside the vault it might be not stored again if you do changes on the files
in that case i would suggest to temporarily store the word document to your unsafe area of your flash drive, make the changes and store again into the vault.
i dont think that there is a possibility to recover your file now.
We no need to worry about these kind of issues because of data recovery software, we can easily get the solution and restore the important data in a short span of time.
deleted files data recovery software
for sure there are many data recovering softwares but if the data is encrypted i dont know what will be the point to recover them if you can open them because of the encryption.
just my thought though maybe it will still work you never know.
Recovery software is an excellent way to backup our files, emails, music, documents and video’s. Day-to -day, Many new versions are available in the market. The work will be very accurate without loss. The benefits of data recovery software can be reaped only if you download or purchase licensing versions from the manufacturer’s website.
best data recovery software
Some data deleted from my personal file last week. I was very worried about it. After that I have found a solution from : http://www.cleverfiles.com/recover-deleted-files.html here. you may helped from here.
Some data was deleted from my personal file last week. I was very worried about it. After that I have found a solution from :
Some data was deleted from my personal file last week. I was very worried about it. After that I have found a solution from : http://www.cleverfiles.com/recover-deleted-files.html  here. you may helped from here.
restore files accidentally deleted from your Computer, Recycle Bin, digital camera, flash drive. You can search from
http://www.cleverfiles.com/recover-deleted-files.html .You also get better solution from google
You may try to use Erelive Data Recovery to recover your files. I use it very well.
you should pay to use the full edition
that was my problem  Subway Surfers Psiphon  Hill Climb Racing
