I have two feature requests for the Cip Zip
Allow me to play music while charging.
Allow the volume to get lower before it is completely off. While studying sometimes it is just too loud.
Note that as to #1, you can play the player when it is charging, if you are charging via a wall/car plug or if you are charging via your computer but using a power only (non-data) USB cable. (Some people also have been able to use a regular USB cable but not insert it fully, or cover up the data pin in the cable.)
And if you are connected to your computer, you can access, via the computer, the content on the player to play.
