Failed Backup
I have a 4Tb My Book, new yesterday, the first backup completed OK, but the next programmed backup (daily) failed with the error - ‘Unable to initialize the backup engine while backing up files to My Book’. The ver of WD Backup is 1.9.6354.40545.
Any answers, please
TerryB
Hi Terry,
I have the same version using on WD Passport; works fine with hourly backups.
That error message almost says that Backup is working on a backup. Was there a date and time at Last Backup to indicate that it was complete? Has anything changed since you wrote your question?
I know this doesn’t help you a lot. Just given some thoughts.
Cliff
Hi Cliff, thanks for your response. I looked at the folders created during the initial backup procedure and they are empty, so no backup of files took place. I uninstalled the WD Backup software, downloaded a new copy, installed it and the same thing occurs. So on the whole a little disappointed to say the least. I might try MS 10 backup and see if that works. Will advise.
Regards
Terry Burke
Terry
Maybe you need WD Smartware. Look up your drive under the Software tab. It will tell you which one to use.
Not sure about using MS Backup. Some WD drives have hardware encryption which blocks MS software.
Cliff
-------- Original message --------
Date:09/22/2017 11:53 AM (GMT-05:00)
To: nh11cnc@comcast.net
Subject: [WD Community] [WD External Drives/External Drives for PC] Failed Backup
TerryB1 September 22 Hi Cliff, thanks for your response. I looked at the folders created during the initial backup procedure and they are empty, so no backup of files took place. I uninstalled the WD Backup software, downloaded a new copy, installed it and the same thing occurs. So on the whole a little disappointed to say the least. I might try MS 10 backup and see if that works. Will advise. Regards Terry Burke
Visit Topic or reply to this email to respond.
In Reply To
Clifford_Cleary
September 21
Hi Terry, I have the same version using on WD Passport; works fine with hourly backups. That error message almost says that Backup is working on a backup. Was there a date and time at Last Backup to indicate that it was complete? Has anything changed since you wrote your question? I know thi…
To unsubscribe from these emails, click here.
