How do i reset my passport after loosing the password, and i have formated it.
I try to formate, but i do not get the orginial partition back…
Is it possible to reset it to orginial settings so i can play movies and look at pictures on my tv
Enter the wrong password 5 times and it will give you the option to erase ( if smartware is installed )
to use with your TV you might need to format on FAT32
