Hai, I have problem with my "wd elements se 1 tb ([Deleted-privacy]). If i connect this external hdd to any computer, it will not open, but the computer detect the hdd by considering it as an unallocated space. Plz help me to solve this. If this cannot be solved, then plz help me to recover the datas inside in it.
I recommend you try using a data recovery software. If you do a web search for Data Recovery it will yield plenty of data recovery software options.
