My WD 1TB Hardisk is not getting detected on my desktop. I tried inserting other USB port hard drives which got detected. I have aorund 900 GB worth data including pictures, documents and movies which i have downloded after much labor. I need to know what am i supposed to do???
Also, my warranty card is not found so want to check can i call customer care of WD who can assist on what to do…or do i need to contact the local vendor in this case being ‘Anupam Stationary’ at Andheri to show them my HDD which they can refer to the company…
-Make sure your device is plugged into a USB port (even if it is not being recognized).
-Open command prompt (Start Menu>Accessories>Command Prompt), right click and run as administrator.
-Type this: sfc /scannow
-Let it run (this may take a few minutes).
-Afterwards, take it out, and plug it into a different USB port (if you do not have one, unplugging and replugging it in should have the same effect i would assume…)
After i did this i could plug it in and it would open with autoplay, no problems at all.
