No problem to access all directories of this external hard disk from my PC (Windows 10), but with WD TV, only somes directories are shown !
Do someone knows the reason ?
Thanks for reply ![]()
Jack
Jack
Hi jack554,
You should try to check after the power cycle of device.
if issue still persists, try contacting WD’s Technical Support about this.
The link below will allow you to call support.
