OK, this is kind of weird but I will try and explain…
my Express will not connect to my PC
when I plug it in it comes up as the mtp device, and says its all working OK
BUT
it does not show up on the PC anywhere, even in the device manager
instead of charging the Express just plays music like its not even connected to the USB
I use vista on my PC and I have checked the USB ports on my PC and there all working OK
I have tried using the sansa updater tool, but it just says that theres no sansa product detected on the PC.
I have also tried the reflashing it (holding the volume buttons down)…this just recognizes it as the number instead of the mtp and im back to square one! I have also formatted incase something on it was causing the problem.
as far as I can tell, it is not because of vista, as my brothers PC also uses vista and it works OK.
on his PC, it charges but sometimes it will not let me move the files.
my express used to work fine on both pcs
any help is greatly appreciated
Bunnyhog xxx
