Experience Sharing: How to Convert DVD to iPad More Easily.
Hi, Buddies! Today i’d like to share with you a magic multimedia conversion tool, which can Rip DVD movies to iPad. It is the seventh app i have tried, which really helped me convert my DVDs to my iPad without any quality losing. This tool enjoys high honor on google and many iPad users.
The reason i’d like to share with you is just because of my experience:
The other days, a very little mistake drived me crazzy on iPad. I planned to copy some DVD movies onto my iPad so that i can watch them when i travel. I think this is a good idea to kill the boring time. However, as is known to all, iPad supports only the video formats below:
* H.264 video up to 720p, 30 frames per second, Main Profile level 3.1 with AAC-LC audio up to 160 Kbps, 48kHz, Stereo file formats are M4v, Mp4 and Mov;
* MPEG-4 Video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per second, Simple Profile with AAC-LC audio up to 160 Kbps per channel, 48kHz, stereo audio in .m4v, .mp4, and .mov file formats;
* Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in u-law, PCM stereo audio in .avi file format.
Audio formats supported like below:
* AAC (16 to 320 Kbps), Protected AAC; MP3 (16 to 320 Kbps), MP3 VBR, Audible, Apple Lossless, AIFF and WAV.
So i spare no effort to look for a DVD to iPad converter, while some can only Rip DVD to iPad, but couldn’t convert to iPad video formats; and some will add watermark on the converted videos, which i can hardly watch on my iPad; what’s more hateful, some free so-called can only damage my DVDs.
The above is my experience, and much more i guess you also met. So i will not waste time on it.
Now i’d like to show you how to do the conversion (from DVD to your iPad) step by step, and also i add some screenshots here.
First, you need to download this DVD to iPad Converter and install it on your computer( Download is free and also it provides free-try function).
Step 1: Run the converter and load DVD
After running the application on your computer, click the “Load DVD” button to input any DVD disc, DVD folder, and DVD IFO.
Step 2: Customize output video
This DVD to iPad Converter owns powerful video editing functions. With it, you can easily trim video length, crop video frame, watermark video, add any watermark to your video and even adjust video brightness, saturation and contrast.
Step 3: Choose proper output profile
This tool provides users with many output profiles. You can click the drop-down list of Profile option and choose the proper profile that suits you best.
Step 4: Start ripping DVD to iPad
After all these settings, you can click on the “Start” button to start the DVD to iPad conversion. After a while, you will successfully rip DVD to iPad.
Now you can transfer the output iPad files to your iPad through iTunes and enjoy them conveniently.
Now i finished and hope my experience and information can really be helpful for you, and also i hope we can communicate on the common habiits.
