Could anyone write out the navigation to activate shuffle mode? My screen is broken so I can’t do it myself. If you dont know what I mean, it would look somthing like this - menu>down>down>select>down>select Thats the kind of directions I’m looking for. Somthing like menu>settings>shuffle would be useless to me because my screen is broken. Thanks for your time.
monkeyfists,
I’m not sure if the menus differ between models, but you might list which model you’re referring to, so someone with the sameone can give you the correct path.
