ETA for new Clip firmware (if any)?
Hey, SanDisk folks:  any ETA for new Clip firmware (if any), and what it will bring (like, folders or gapless)?  It’s been about 3 months since the last firmware revision …
:wink:
Thanks!
by my calculations it should be the next week or the one after :wink: unless there’s some unexpected delays :slight_smile:
Do you know whether there are any plans to fix the gapless issue with the new firmware???  I’ve just bought 2x Clips to replace “on they last legs” iPods and the gapless is the only thing that is annoying the hell out of me!  I’m toying with the idea of sending them back, but if its going to be fixed that I will hold on :neutral_face:
Cheers
Yep, that’s assuming a 3-month schedule or so for revised firmware.  Would be nice to hear from a SanDisk rep. on this …
