Any info that can be offered on the following would be greatly appreciated.
I just did my first backup with a new Passport Ultra 1 Tb external HD. OS is Windows 7 64 bit. Used the Windows Backup and Restore feature in the OS. I did not load the WD software on the HD (only the SES update). The backup and system image were completed with the following skipped files:
Backup encountered a problem while backing up file C:\Users\Administrator\AppData\LocalLow. Error:(The system cannot find the file specified. (0x80070002))
Backup encountered a problem while backing up file C:\Users\Administrator\Contacts. Error:(The system cannot find the file specified. (0x80070002))
Backup encountered a problem while backing up file C:\Users\Administrator\Searches. Error:(The system cannot find the file specified. (0x80070002))
Why were these skipped?
What are these files? Are they significant?
If I ever need to restore my files, will these skipped files inhibit or prevent it?
Can I do something to capture these in my next backup?
Thanks for any advice that may be offered.
