error codes and what do they mean?
When I try to sync tracks to my device this appears. “Cancelling inspection of files on device”. After it’s done inspecting, it disappears and the tracks that I dragged to the sync list doesn’t transfer to my device. Note: Sometimes it will allow a few tracks to transfer but most of the time it won’t. So frustrating.
Another reason to hate WIndows Media Player.
http://forums.majorgeeks.com/showthread.php?t=143778
You can also sync with www.mediamonkey.com and winamp (www.oldversion.com, search for Winamp).
Or you can go to Settings/Systems Settings/USB and change to MSC and then just drag-and-drop what you want directly.
I’m using mtp but I’ll try msc and see if that works.  Thanks
Thanks Black-Rectangle.
