I have already using a WD elements 500 gb. Today I decided to buy a 1 TB WD elements. I bought it and started to use it. When I try to store the large files, after few minutes my computer stops recognizing the device and it gives the error code
Error 0x80070037
What can I do about this topic ? I don’t have anyproblem with 500 gb one, but 1 TB one does that problem. Otherwise I am gonna send back my device and gonna buy another brand.
I thought it was the HDD
I thought I had the latest drivers
Turns out I wasn’t looking in the right place for drivers as I did a check for updates but came back with none.
If you know what motherboard you have, go onto their website and find your model number and download the USB drivers.
When I installed mine, it unistalled them first time and had to run the install a second time.
After many tests of transferring a good 100gb to it, then back off it to main hdd, then again with another 100+GB of different files all without fail, I can safely say this has resolved it.
I too started transferring files only to get a few hundred MB’s in and it come with Error 0x80070037 and it disconnect from My Computer.
