My WD Elements doesn’t show up.
I’m running macOS 10.14.6 on my iMac.
The drive shows operation light on, I can see the specifications of the drive in the Apple menu → System overview → USB connections listed as ‘Elements 107C’. However, the HD doesn’t show up in the Finder nor Disc Utitilies. Is the drive damaged or is the cause of failing connection system based?
Might be that the power supply is not the right one, can anybody provide the specifications of the needed power supply for the device. Currently I’ve got it powered up wth a 12V, 900mA adapter. Since the operation light works I guess that it works.
Thank you for reply. I checked the adapter and it is a 1.5 amps adapter. I thought it was 900 mA given the information in my System Overview. So, that shouldn’t be the issue.
Can you feel the drive spin up when plug in? Open up the case check of the drive connection is loose from the bridge. If everything check OK, then the drive could be dead.
