EDB to PST Converter tool
Well if in case, you are looking for the simplest method to export the Exchange EDB database then do try a tool like eSoftTools EDB to PST Converter tool. This software has the ability to re-establish the entire mailbox in a different file format which includes options such as EML, EMLX, HTML, MSG, vCard, PST, CSV, etc. Also, the user can use this tool to divide huge PST files into small segments of new PST files. The data and the folder structure are not changed in the entire journey of data exportation. A free trial is also available easily on the official website to test the performance and feasibility of the software.
Read More Info- EDB to PST Converter tool
You can download now Enstella Exchange EDB to PST Converter Software which has the capability to simply make recovery all Exchange mailbox items such as- attachments, emails, contacts, tasks, notes, journals, appointments, etc… from the EDB file and save them to PST. With the help of this program, the user can smoothly repair the corrupt EDB file to reuse the lost items of inaccessible EDB files.
Get freeware to click here-https://www.enstella.com/edb-to-pst-conversion.html
