I have a 4 TB Easystore portable drive. I formatted it and 2 TB are allocated, but I still have a partition that is unallocated. How do I allocate it?
Thanks.
Thanks.
Hello, dmoranok
Well, formatting a partition drive does not make any changes on the partition that you have made, Partition can manually be removed or can be removed by formatting the drive in low-level. If you are a windows user then the given below article is useful for you.
If the issue persists then you should try contacting WD’s Technical Support about this.
