Just got my SlotRadio Player and it is just what I needed. I can’t figure out how to download from the “Net” so the Slot is great. My question is can two people listen at the same time? It would take a “Y” connection, do they make such a thing? Wife and I are going on a long bus excursion and it would be nice if we both could listen to the same songs at the same time.
I’ve seen what you’re looking for at Radio Shack and other places.
As long as you both like the same music and the same volume level, this should be just the ticket.
http://www.radioshack.com/product/index.jsp?productId=2123235 $10.99
OR
http://www.radioshack.com/product/index.jsp?productId=2062454 $5.99
Thanks for the reply. I’ll give that a try. Wasn’t sure something like that existed.
