hi,
recently i have a problem with my e270v1.
it is functioning ok, but cannot connect to the pc (3 different pc’s, with win7, ubuntu and xp).
the only way i was able to connect it was in manufacturing mode to ubuntu.
i have tried the following things:
switch to msc mode.
buy a new cable
manually update firmware and bootloader and format using the e200tool (with .rom .mi4 and sansa.fmt)
disassemble and reassemble the memory daughter card.
clean connectors with alcohol.
write a working firmware image over the hidden partition (using e200tool)
do you have any other ideas for how to solve my problem?
thanks,
nir
