When I search for album art on the Internet there are many different resolutions available. What is the maximum resolution that the e260 can display? I assume it is the same for the entire e2xx line of products.
JimR
JimR
i don’t know what’s the max size but i think windows media player set it at 75x75px (the one displayed in the screen while the song is playing) and 200x200 (the bigger one)
If you are using a program that works with The Sansa, it should work fine with any album art as it will compress it. hoep this helps ![]()
