I recently upgraded the firmware on my sansa e260 as it had frozen. My problem now is that after adding the firmware, the option for: " custom" EQ settings is gone… I have the other standard options ie: rock, hip-hop, normal etc, but the option for " custom" where the user is able to customize their settings has vanished. Any help would be appreciated.
What firmware version is it? I can confirm 1.02 and 1.01 both work, perhaps you have the newest, thats buggy?
i installed 01.02.18A worked like a charm… thanks a bunch!!
