# Dying mybooks
**URL:** <https://forums.sandisk.com/t/dying-mybooks/361616>\
**Category:** External SSD for macOS\
**Created:** [May 14, 2012, 3:17am UTC](https://forums.sandisk.com/t/dying-mybooks/361616 "2012-05-14T03:17:49Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![mhnwd](https://avatars.discourse-cdn.com/v4/letter/m/94ad74/32.png) [@mhnwd](https://forums.sandisk.com/u/mhnwd)\
**Post date:** [May 14, 2012, 3:17am UTC](https://forums.sandisk.com/t/dying-mybooks/361616/1 "2012-05-14T03:17:49Z")
</div>
In the past 6 months I have had 3 , two teribyte “my book” drives die. The last one was sent to me to replace a dead unit by WD one week ago. Someone , on another. Forum, said that this device was not designed to be on all the time. I do not use this as a backup device, it stores the gigabytes of video that I work with every day. Is this designed to be turned on, used and then quickly turned off before it dies??? The power adapter, although small, is able to light up a 12 volt car tail lamp, so I guess the problem is not the power supply. Can anyone confirm that this drive is not designed to always be on?? Thanks
**Author:** ![Wizer](https://avatars.discourse-cdn.com/v4/letter/w/43a26b/32.png) [@Wizer](https://forums.sandisk.com/u/Wizer)\
**Post date:** [May 14, 2012, 6:24pm UTC](https://forums.sandisk.com/t/dying-mybooks/361616/2 "2012-05-14T18:24:05Z")
</div>
I will let WD tell you on this link :
[Leaving an external hard drive powered on all the time](http://wdc.custhelp.com/app/answers/detail/a_id/1386/session/L3RpbWUvMTMzNzAxOTc5OC9zaWQvVkJ6Q2U2WWs%3D)
