I had one Windows Media Player playlist set up that worked fine. I found one more song that I wanted to add. I edited the first playlist and now have two with the same name. The second one plays all the songs including the one added, but there are two playlists on the device with the same name. Is there a way to delete the first one? Windows Media Player only seems to show the second one. Thanks. I love the machine!
I figured this out. Windows Media Player tracks the date the list was created and modified, but leaves only the modified one. The player keeps both, which is kind of cool. Sorry to ask a stupid question.
im very glad that you found a solution to your issue and you posted the solution on here so others can also learn something from it to prevent from happening.
