Dual partiton ultrbackup 64gb?
Is it possible to create two partitions on this? I need one 16gb FAT32 for my car radio and would like the rest NTFS for general storage? Just having seperate folders won’t work. I’ve done some searching already and didn’t find any clear answers. I’m pretty sure this means I need to flip the removable media bit too. Thanks
Linux can see multiple partitions on removable drives but Windows can not, by design.  If you are running Windows and wish to see multiple partitions you need to install either cfadisk.sys or dummydisk.sys which will give you that ability.  However, other pcs without these files will only see the 1st partition.
[A Multiple Partition USB Stick with Multi Boot OS - Multi-Boot CD/DVDs - MSFN](A Multiple Partition USB Stick with Multi Boot OS - Multi-Boot CD/DVDs - MSFN st 54)
