I have been looking at the Sandisk Memory Stick Duo Adapter to use in my DSC-F707 but I cannot get a straight answer from sony. Does anyone have any idea if the DSC-F707 will accept the Sandisk Memory Stick Duo Adapter and the various memory sticks available for the adapter?
Just a suggestion . . . You might get more responses if you explain what a DSC-F707 is. ![]()
sandisk does not ahve that camera listed in their compatibility database so the best way to get an answer would be from sony. that being said does the card use pro duo cards or full size memory stick pro or regular memory stick?
sandisk does not ahve that card on their compatibility data base so sony would proably be the best people to ask. that being said does the camera use pro duo cards, full size memory stick pro cards, or full size memory stick?
