Dropped my My Book Essential
Hi all, Managed to drop my 1TB My book essential, In the fall it ripped out the usb connector.  I have taken it out of the case and the USB connector is on a  small  component/card?  Will  a local computer repair store  be able to bypasss this connection and retrieve my info, or will I need to buy a new component/card.  I live in the UK  and I’m not sure if these components are available over here. Thanks
Hello, depending on the my book model you have, it could have data encryption, so you might be able to fix it with a new PCB board, but you wont be able to recover your files.
Another board might work or maybe soldering on a new port. The drive may also be physically damages and need professional recovery. The more you mess with it yourself the more difficult professional recovery becomes.
Joe
Thanks for the help, will visit my local computer store before I cause more problems
