This has run fine for 3 years now but suddenly lost its WD reference in “My Computer” and has just been given a standard drive reference of “I”. When opening, it shows as full, no space, no files yet there are over 22k photos on there visible with recovery software.
XP “System>Hardware” shows Buttons and Lights as missing a driver. Trying to reinstall the software or find a driver just doesn’t work. Any ideas anyone?
So you think it’s the drive, not XP. I thought maybe if I could find the driver it might be OK, oh well…
While I say I can see it as a drive, I can’t see it as a WD drive as per previously.
I had no need to recover the software as this was one of a pair of backup discs but I did try it with PC Inspector, a free download and it recovered every single file with no problems. Took around 24 hours to do though!. Is there no way of getting it back to life then?
