Drive shows as 'Local Disc'
Hello all. As of today, my WD MyBook external Harddrive is showing as ‘Local Disc’ whereas it used to show as ‘F Main External Drive’. The drive is no longer accessible. I’ve swapped the cables as used it on another PC which still shows the same errors. I downloaded and used WD’s Lifeguard Diagnostic tool, which still shows the drive as ‘MyBook’, so it is still there.
Hi River0745,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
