Drag and drop
I just installed my passport ultra 2 TB.  When I try to drag and drop a file into it, it doesn’t close when the copying is finished.  It just continues and the only way out is to close Windows explorer.  I use Windows 7 64 bit.  Did I miss smething n installation ?  Any help ?
The copy process is handled by the OS and the drive needs to be closed once you finish copying the files.
There are many other ways to copy files to the drive. Try the methods provided on the link bellow.
Recommendations on how to back up data
http://wdc.custhelp.com/app/answers/detail/a_id/1055
thanks for your help.  The link didn’t specify Passport Ul;tra, but I readi through the others, and I can now drag and drop both files and folders.  Thanks.
