Download OST to PST Conversion
*             Using the best OST to PST Concerter tool you can get 100% perfect result because with help of this tool you can save mailbox into a cloud-based application Office 365 & live Exchange Server which is an additional feature.
*             The OST to PST conversion tool divides large OST file into small PST file.
*             Outlook OST recovery tool is required which foremost works with all the versions of MS Outlook 98, 2000, 2002, 2003, 2007, 2010, 2013, and 2016.
*             Outlook OST Recovery tool gives 24x7 technical support.
 *           InQuit OST recovery tool supports OS Windows 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit) without difficulty.
*             This application supports live Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013, 2016 and 2019.
You can gain the discount offer up to 80% on this product by visiting the official website (bold and highlight this line).
Read More Info: https://www.inquitsoftware.com/en/ost-to-pst-converter.html
OST to PST export tool is the advanced solution for Windows smoothly transfer inaccessible offline OST file/folder to PST Outlook format and also simply works to convert OST data into several file formats such as EMLX, Gmail, Office 365, EML, vCal, vCard, MSG, MBOX, and etc. file format. This software supports OS Windows’s version 98, Win NT, Win ME, Win XP, Win Vista, Win7, Win 8, Win 8.1, and Win 10 (32bit & 64bit.
More info- KDETools for OST to PST Converter
