Hi all
I have a new m200 MP3 player, and I want to download Hebrew menu to it.
Is there anyone who knows how to/ where to do it?
THX
Sinay
Hi all
THX
Sinay
You need to install the Hebrew firmware on the device
If you don’t have it yet, download and install the the Sansa Updater utility to your PC
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
Then after you’ve installed it, plug your player in MSC mode and update the firmware to Hebrew
If you don’t get the option for Hebrew fimware in the Sansa Updater then it is not supported for the m200
The newer Clip and Fuze do have full Hebrew support
