I just bought my Fuze yesterday (and this is the first real MP3 player I’ve used other than a cheapie)–I charged it up and loaded some songs, and they play…when I can get to that. My problem is, I seem to be able to scroll left and right but not up and down so I can select other menu items. Once in a while I can get it to move (like from music to video to settings), but not all the time. I saw this description in another post (which is pretty much what mine seems to be doing.) I have XP and I don’t even know which version of WMP (I’m at work), but that part of it seemed to work fine. Is this a hardware issue where I should just take it back, or is this something a software upgrade could fix?
…the thumbwheel wont
scroll. I basically have no control with the volume but when you press it left, right, up it works and it also came to my attention
that when i press the down button when its playing music, it goes to the music options but then if i try pressing it again it wont go to
the next option.
