Does The WD 2 TB USB 3.0 Elements Desktop Hard Drive Hibernate?
Hi .
I am going to need to buy 3 new external Hard drives to replace my current full WD ones which are full.
My current Green Element ones sleep or hibernate I believe.
I like this feature.
Question ;
Do the WD 2 TB USB 3.0 Elements Desktop Hard Drive for Plug-and-Play Hibernate or Sleep or do they run all the time even if not being used ?
Also do they have a ON/OFF switch ?
I was looking at bying these - http://store.westerndigital.com/store/wdeu/en_GB/DisplayProductDetailsPage/ThemeID.22586100/categoryID.67933000/subCategory.67933200/parid.13831800/catid.13832200/WD_Elements_Desktop
Kind regards
Jeff
Hello, all WD Elements go into stand by mode after certain amount of time without use. The one you are looking into buying does have a power button.
Thats great.
Thankyou
Got the WD Elements 4 TB USB 3.0 a month ago, to use as the backup option for WD My Cloud 4 TB. It properly goes to sleep mode when inactive. Now, if only the WD My Cloud could do the same, this would be perfect.
