Does SanDisk think on to release a cure or an update for SecureAccess errors??
As everyone on here has mentioned about those errors, does SanDisk consider to release a kind of decryption program or an update for its useless program SecureAccess V2.0?
I think i am gonna sue SanDisk, if they won’t find a well solution for this.
First of all Secure Access is not a Software from Sandisk but from Encryptstick, you can see this if you start the software. So you will sue Sandisk for a non Sandisk software.
In that case sandisk just provides this software as a free gift with the cruzer drives, if you do not consider to use this software you can just delete it and use the drive normally.
