I am going to buy a sansa fuze and sometimes i listen to chinese songs. Does fuze support chinese characters and is it convenient to creat playlist or folder containing chinese characters?
Thanks!
Thanks!
Yes, Fuze does support Chinese ID3 tag in both simplifed and tradiitional font. I haven’t test out the playlist function since I don’t use it, but it should be any problem at all for the Fuze. Just be sure to tag your song correctly.
yes try to choose pacific region in the firmware and see if you can have the chinese character and it should be suoorted.
Where can I get a Chinese language user manual for the Sansa Fuze (not Fuze+)?
Thanks,
Max
Here’s what i found on their Global site.
It should be the first result
http://kb-cn.sandisk.com/app/answers/list/kw/fuze%20manual/r_id/158/search/1
