Docking Station
Got the docking station up and running. Does it harm battery at all by leaving the fuse plugged into the dock all the time.
Going to modify the larges plastic insert to support the fuse, don’t really like not having a back support when plugged in.
The Fuze automatically manages the charging operation, going to a float status once the battery is topped off.  Note how it gets warm when initially charged?
If the device is left overnight, the display is automatically shut off, and the device will be quite cool to the touch.
The battery in the Fuze is designed to operate like your car’s battery, normal operation with regular topping off is the way to go.
Bob  :stuck_out_tongue:
