i need to know do i get normal charger
thanks
thanks
No (wall) charger included – bur a wall powered PC can be your charger.
Many (wall) chargers available on the web with USB port. Careful not to exceed 5vdc output. One inexpensive solution is to use a phone charger for Motarola Razor. This is what I use. Can find this at any flea market for about a buck.
I found a very inexpensive wall charger on Ebay that works fine. There are many of them there. It plugs into the wall and has a USB jack. I used it to charge the Clip+ with no difficulty.
