Do some Clip+'s have Shutting down Faults
My clip+ just shuts down!It’s happened several times in the few weeks I’ve used it,though to keep it in some perspective I use it for many hours everyday day. At first I presumed that maybe because where I ‘clip’ the clip+, the buttons,which face up against my body, were accidentally getting pressed.As far as I know the only way to manually power down the clip is by holding and pressing the power on/off button onto of the clipped I can’t see how I can be accidentally pressing & holding this button long enough to turn the clip+ off accidentally.
Anyone else noticed  these kind of  Random powering off issue’s ?
I would see about getting another under the 1 year warranty. It should not be doing that.
ok will do thanx
i have 2 san disk  1as a clip 1 as a 2.o gd i can not get it to work with card     ann
Translation, please?   :wink:
eep opp ork a a
Bob  :stuck_out_tongue:
