Do anybody know whats the problem is?
hi…
Iam Dinesh,I hv bought my 1tb MY PASSPORT ESSENTIAL SE HDD about 2 weeks back. It has worked normally till date but suddenly when i plugged in my HDD my PC was not recognising any HDD but the LED light adjacent to the HDD was glowing when i connected to my PC. I thought it would be some problem in the USB slot but it is working normally when i inserted my other pendrives. Do anybody know whats the problem is??? :frowning:
Reply soon…!!!
Thread moved to WD External Drives: My Passport for PC.
Regards,
HI  dinesh:manvery-happy:
I am Ali from Saudi Arabia
I have the same problem:manmad: that you talking about .
I bought  “WD My Passport  Essential  USB 2,0”  befor 6 months , untill yesterday there is no problem.
Yesterday when I try to plug my HDD in PC  >> It can’t ricognize it .
If there some one can help us to fix these problem?:womansurprised:
I ot the similar issue since last week, I brought this WD pasport 1 TB drive on november 26th 2010. It worked well allthe time. I copied almost 200 GB of data into it. It stopped working all of a sudden when I was copying 20 GB data at a go with a pop up message “write falied delayed…”.
Please share your solution to this.
Thanks,
Sudheer
sudheerkumar wrote:
Thanks,
Sudheer
if you haven’t damaged the port or the drive, you may just have a bad cable.  replace the cable, but remember to use a short, eighteen inch cable.  And don’t use a usb hub.
dinesh_alapati wrote:
hi…
Reply soon…!!!
you may want to check out the post below.  it gives some simple troubleshooting tips.
http://community.wdc.com/t5/My-Book-for-PC/FAQ-External-hard-drive-no-longer-shows-up-in-My-Computer-and/td-p/133426
