display shows defective images
hello everybody,
I’d be really pleased if you hepled me…
lately, my sansa fuze 8GB (+ additional miniSD Card 4GB) is defectively showing awkward images.
i uploaded some that i photographed so you can check visually:
http://i39.tinypic.com/nn8j8o.jpg
http://i44.tinypic.com/110am1j.jpg
I already formatted the player and the SDcard on the computer, but there was no change
i also managed to format the device in the player menu, as the display sometimes shows the menu and the point you selected with the wheel in a mirror-image (uploaded photo 2), but the distortion of the display did not stop
thank you for your help!
You could try manually re-applying the firmware. If that doesn’t cure it, it’s toast. Get a new one.
Have you tried holding the power switch(about 10-15 seconds)? That happened to me once, and I had to perform a hard-shutdown. try it.
