Display cracked - Changing the display
Hello community,
through an unfortunate mishap the display of my Sansa Clip Zip broke completely. It’s not working anymore at all.
It broke because I didnt store the device properly. I already contacted the support, but the only the thing they could (correctly) tell me is that it’s my own fault and they therefore can’t help me.
I wanted to ask if this happened to anyone of you before and if anyone managed to repair it using spare parts?
I am glad for every help I can get.
Cheers,
Chris
So sorry about the damage. I think you should be able to get the display part in a spare part shop and get it fixed by an engine. Those support can be funny sometimes. Or you can check here for other alternatives https://dynamo-led-displays.co.uk/
