Recently I cannot access the Disk and I tried quite a lot of different methods:
Windows Explorer: No response, the drive cannot be mount
Windows Task Manager: shows that 100% active time all the time with ripples at the disk transfer rate.
Windows Disk Managemen Tools: Hangs Over at “Connecting to Virtual Disk Service…”
Mac: Cannot mount file, sometimes if really can mount, file names have been shown but cannot copy.
Mac Disk Manager: Cannot repair the damage…
WD Disk Smart status: normal
WD Quick check: normal
WD Full check: Perform up to 40% and hangs.
Cable changed: No difference from the aforementioned status
Is my harddisk doomed? Any way to recover the data apart from finding those expensive recovery services?
Thanks & Regards,
Ernest
