I have old music on my e200 which was synced from older computers from windows and now have windows 7, but the library on my e200 will not show when I go to My Computer and select my e200. Any suggestions to make the playlist of albums appear so I can select and delete ? Thanks
Try switching the USB Mode (Settings menu on your player). Try both MTP and MSC.
My settings menu does not offer a USB mode option ? Format ?
If you don’t have a USB mode option, you have a (very) old firmware. You can update the firmware without losing your files, so you should then be able to switch modes and find your files. Just check the “User Guides/Firmware/Software” forum for the appropriate topic.
You can also “force” MSC mode:
MSC mode instructions:
- Turn off the e200 v2
- Put the device in Hold (move Hold button until orange is showing)
- Press and hold the Left Button
- Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
- Wait for the e200 drive(s) to show up in Windows Explorer.
