data recovery, faulty controller
Hello, I really need some help recovering data from my microSD card.
It has hundreds of holiday photos on and then it stopped being recognized in my phone. I really want to recover the pics so I took it to a local PC store who assessed it and said that it had a faulty controller, so there was nothing that they - or anyone else - could do.
Is this correct or do I still have a chance to recover the data??
Did you try to connect the micro SD card to computer with card reader?
I did. I tried it on my PC and laptop, and tried 2 different SD adapters with each, just in case, and it wasn’t recognized by either.
It’s definitely faulty, and apparently it’s the controller that is failing, so I just want to know if there’s any chance of recovering my photos??
you should contact a comapany that specilizes in data recovery. SanDisk recomends LC Technologies you can find their informaiton at www.lc-tech.com
url=[https://www.edbmails.com]EDB to PST [/url]Converter repairs corrupt or damaged Exchange EDB files and restores the mailboxes into Outlook PST file. You can easily view Mailbox data from the PST files using MS Outlook application. It supports MS Exchange Server Recovery for 2003, 2007, 2010, 2013 and 2016 corrupt and unmounted database.
Recovers Calendar, Attachments, Drafts etc., from the damaged EDB files
EDB to PST Exchange server Recovery tool helps you to recover mails, images, attachments, drafts, calendar, journals, appointments, tasks, notes, etc. from the damaged EDB files. Its ease of use GUI enables you to preview recovered mail items.
– Recover / Restore only required Mailboxes
– EdbMails capability of granular / brick-level mailbox EDB to PST conversion support, will help you to recovery any desired Mailboxes data.
– Automatic handling of PST file size limit
– If the Outlook PST file reaches size limit then, EDB to PST Converter will automatically split the PST file into multiple files based on the size limitation of the Outlook PST.
– Recover Deleted Mailboxes
– Edb to PST converter can easily recover mailboxes, which have been deleted knowingly or unknowingly.
– Recover and Save as EML, MSG format
– In addition to saving the recovered data as PST file, it also allows you to save the recovered data as MSG, EML formats.
Also Visit:
url=[https://www.edbmails.com/pages/ost-to-pst-converter-for-ost-to-pst.html]OST to PST Converter[/url]
url=[https://www.edbmails.com/pages/outlook-pst-recovery.html]PST Repair Tool[/url]
Many OST Client finding that software that solves their OST files problems like EML, CHATS, NOTES, Calendar, Task, Journals and many more issues related to OST file for those eSoftTools Has brought most useable tool name eSoftTools OST to PST converter Software this tool is the best solution of all OST related Problems.
Read More:- https://www.esofttools.com/free-ost-to-pst.html
